Fixable or for the bin? iPhone 3G Unlock
Frank Harvey
Mar 2, 2013
hi
i bought an iPhone 3g on ebay for my other half,it was jailbroken and unlocked.
after a while it would switch to the Apple logo every 5 or ten minutes,this would last for a minute or 2 then come back on
foolishly and being a bit stupid about these things i restored it on iTunes hoping it would cure the problem,now i cant activate it, i don't know who the original carrier was, and when i use my o2 sim
it just keeps saying searching on the top left
is it fixable or for the bin
thanks
frank
liberated
Jul 19, 2007
3,238
484
hi
thanks
frank
Look up Redsn0w on google and use that method to restore to a JB and unlocked state.
Check this video for help too
liberated
Jul 19, 2007
3,238
484
hi
thanks
frank
iphonewarrior
13,847
699
The best thing you can do is to jailbreak your device. As you said it's a 3G and you've restored it that can only mean you're on 4.2.1. Jailbreak using Greenpois0n RC5.2 which you can download here. Once you've jailbroken you will need to upgrade your baseband to the iPad's. This is fully reversible don't worry...
Once you've jailbroken and installed the iPad's baseband you can downgrade the baseband to another unlockable version which doesn't affect your GPS etc. Once you've done this, just go about your businesss with an unlocked iPhone 3GS.
Here's a guide.
Frank Harvey
Mar 2, 2013
i am in the process of downloading the suggested software, the iTunes restore put it on (6.1, oldBR, 06.15.00)
does that make a difference?
thanks for the replies
frank
Frank Harvey
Mar 2, 2013
frank
Frank Harvey
Mar 2, 2013
Download Redsn0w 0.9.15b3 (or newer) for OSX or Windows.
Open Redsn0w and select “Extras” then “Select IPSW”. Select the Stock iOS 4.2.1 firmware you downloaded in the step previous step. Do a controlled shutdown of your iPhone (“slide to power off”): this step is very important to avoid mount problems. On Redsn0w click “Back” and you will see the initial window. This time click on “Jailbreak”.
Enable “install Cydia” and “Downgrade from iPad Baseband” checkboxes. Click “next” and “next” to proceed through the normal DFU steps
The flashing process will begin: don't touch the device and don't disconnect the USB cable. It may take up to 10 minutes.
went though the whole instruction perfectly, now the phone is waiting for the last 40 minutes with "waiting to reboot"will wait another 10 minutes before quiting redsnow........................unplugged after 60 minutes waiting and.....back to "could not activate iPhone"
