Tech. YES but not easily. It looks like the iPhone will be sealed so getting it open will be a problem.
Sure, ok, anything can be removed. Its fully removable, haha. They designed it that way so it was easily upgradable. not.Even if it is soldered it can still be removed.
Your right anything COULD be removed, its getting it to function completely after adding another that is tricky. He didn't ask if we could upgrade it just if it was removable.
I would bet you are able to use the drive option like on all the other iPods.Not that you would really want to use it as such, but will the iPhone have the "Use This As An External Disc" option in iTunes to add files and such? Theres one or two files I would like to have with me.
Or would it be better to just email it to myself and then be able to view them.
I hope so! One more device to get rid of: thumb drive.I would bet you are able to use the drive option like on all the other iPods.
Yup, I concur. Just need to carry an iPod USB cable.I would bet you are able to use the drive option like on all the other iPods.
What I want to know is if you can sync wirelessly via bluetooth, forget the stupid cable. Macbook Pro has bluetooth and so does the iPhone, so why not?Yup, I concur. Just need to carry an iPod USB cable.
I'm with you on this one. Check out this thread.What I want to know is if you can sync wirelessly via bluetooth, forget the stupid cable. Macbook Pro has bluetooth and so does the iPhone, so why not?
Thanks! I sure hope David Pogue is wrong though.I'm with you on this one. Check out this thread.
Time to buy a Mac!Bluetooth would be nice if you could hook it up that way. I don't have bluetooth on my pc. I need to fix that.
You can pick up USB Bluetooth adapters for pretty cheap these days. That should fix it up right!Bluetooth would be nice if you could hook it up that way. I don't have bluetooth on my pc. I need to fix that.
