Flashlight in control center not working
ironlungakc
Aug 26, 2007
94
I'm having a problem with the Flashlight app in Control Center. When I swipe up to access control center, the Flashlight has grey. I cannot see it, but tapping does not turn it on. I don't remember deactivating it in any way, so I'm not sure why it's not working. I'm not sure what to do. Any suggestions?
I've attached a screenshot that shows what's happening.
Sent using iCafe app
5,580
Try using the flash while taking a picture then check to see if flashlight option is no longer greyed out in Control Center.
ironlungakc
Aug 26, 2007
94
Worked like a charm...Thank you!
