Flytunes HELP!
mstx
Jan 10, 2008
21
hey i registerd for flytunes then i entre to their site and went radio stations so i chose HITZ and then it showing that i should wait and after 5-10 sec's showing down a PLAY Button so i clicked on it , its changed the play button to red color so i don't hear anything and the DOWNLOAD! word above disappear then after 5 seconds the play button will change back to normal color its look like i should click again to play the radio but i did several times .. so can u help me please do u have any i dea ... And thx , sorry about my english tell me if u don't get me..
Btw i put wifi option not Edge and tried all stations same problem
GADeputy
Jan 21, 2008
381
Georgia, USA
Don't hit the play button. When the right amount of music is buffered it will start playing all by itself.
mstx
Jan 10, 2008
21
aha i will try that and tell u later thanks anyway :)
mstx
Jan 10, 2008
21
hm i just tried to wait as long as i can but nothing much its just say "press the play button to start listening to the station." so i didn't press it as u said .. :(
GADeputy
Jan 21, 2008
381
Georgia, USA
Hmm... it's working fine for me. I'm listening to Hitz right now.
Try listening to a different channel. Click on the channel then let it load up till it starts playing on its own. Works for me every time.
IphoneTony
Nov 10, 2007
2,164
New Jersey
you might have a low signal... should download within a few seconds... Could just be a problem with flytunes at a certain hour when too many people are logged on... They are still a new service and updating there system still
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Also notice on the lower right screen, there are 2 buttons. One is for wifi and one is for edge. Make sure you press the one that applies. And of course edge will be slower. Notice when you press edge you have fewer station selections.
GADeputy
Jan 21, 2008
381
Georgia, USA
OK, now I have a FlyTunes question.
After you pick which channel you want to listen to a screen comes up right before the music starts playing (the screen that has the wifi and Edge symbols) that has 4 icons near the bottom. I know the first icon is to go back, the 2nd is to add the channel to your Presets, the 3rd icon is the Play icon, but WHAT is the 4th icon for? It looks like a music note with wings. Anyone know what that does?
I've never had a problem with FlyTunes so I never bothered to find out what it's for.:p
Nevermind, I pressed it to find out what it does.
It's to e-mail someone the music link.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
That is to send an email to someone for that station.
I need to read the whole post. Didn't see the edit portion.:oops:
mstx
Jan 10, 2008
21
:oops: Still now working , i tried everything .. and i checked the 2 button lower right screen its already wiFi .. but above its showing DOWNLOAD! i click on it , its like just a picture i cant click .. and the PLAY button still same .. and i tried to wait very long without clicking on PLAY button and nothing lol .
maybe the problem is i live here in United Arab Emirates - Dubai ?
or flytunes work all over world?
IphoneTony
Nov 10, 2007
2,164
New Jersey
well now you bring up a good point maybe its because you live far far from flytunes... but since its on the web I don't see that being a problem but who knows... you have exhaused all the reason I could give you ... Good luck in future...
enigmanic
Jun 27, 2007
513
Are you, by any chance, jailbroken with Safari Download Plugin installed? If so, that's why you see the "download" icon. You'll need temporarily disable Safari Download Plugin to get FlyTunes working. You can do this by installing NetServices to toggle Safari Download Plugin on/off. Note: if you're jailbroken on 1.1.3, you'll probably need to change the file permission to get NetServices working properly, since you're now running as "mobile".
mstx
Jan 10, 2008
21
hey man thanks so much its working u were right it was from download plugin i make it off so nnow its working and lsning to it right now and thanks again guys
