FM adapter for the iPhone 4?
Bryman
May 30, 2009
224
colorado
im needing one of those fm transmitter things for my iPhone4, for my work van......what do you all suggest?
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
I've tried using one of the cheaper FM transmitters in my car and found it very frustrating to the point of being useless. With the airwaves so crowded it's difficult to get a clear signal that will last long enough to make it worthwhile. From what I've read in similar threads over the past couple years, even the more expensive models aren't worth the trouble. You might have better results depending on your area but if you buy one be sure to save the receipt ;) My current vehicle has a tape deck whack an adapter works fine for. My next one will have a USB port.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
I've tried them all, from the cheap to the the expensive. They all suck IMO. My advice would be to get one you like and try it. They all seem to have the same quality. Like I said though, it just my opinion from my experience.
katelynneemma
Jan 15, 2011
683
98
33
N.Y.
I discovered by accident actually,that my phone will blue tooth to my car radio and play like that. I would see if your stereo had that capability.
Dynamic8
Oct 13, 2011
China
I find it is cool to have a All kit FM Transmitter in the work van to enjoy the perfect music playing. With that device i could hand-free chatting with others while busy period.
