FM Receiver
HeyRoss
Aug 10, 2007
Does anyone know if the FM receiver headseat will work with the iPhone.
I love my music catalogue but like to listen to FM morning shows too, you know?:cool:
UPDATE:
I just tried plugging one in and got a message on the iPhone that this device is not supported. BOOOOOO!
Anyone have any other ideas or insights?
Please post if you would want FM on your iPhone.
gkreed
Jul 17, 2007
45
I would love to know this also.
minivini
Jul 6, 2007
418
UPDATE:
Did you try using it anyway? Usually when an accessory is plugged in, you get the incompatible/airplane mode message. Very often the device works as it would with any other iPod...
skiz420
Jul 28, 2007
371
Boston
thats one of the first things i pulged into my iPhone.. if it worked it would be a great adon... you could use it for FM, a controler, and best of all use your own dam headphones without another adapter... but it gives you that stupid message that it is not supported but i believe it could be added on with a firmware update... seems the software to run it is just not on the phone as of yet... then again Apple may just make the "iPhone FM adapter" to get you for another 50$
