Foggy camera lens
Dcgirl12
Aug 12, 2010
Hi I was walking in my neighborhood when a thunderstorm came out of no where.I had the phone in my pocket to protect it as much as I could. Everything works but the camera lens is now foggy. Will this eventually go away?
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Look in the headphone jack. And in the dock, what's the color?
Apple fan
May 31, 2010
244
Lutz, FL
Don't worry about it. If the earphone jack is pink and everything works flawless. Don't worry about it. But. If in fact you need to meet a genius at the genius bar the will see if it is water damaged and you will have to shell out another two hundred big ones.
Dcgirl12
Aug 12, 2010
Thanks guys.Everything else on the phone works fine and the headphone jack doesn't appear pink but will the fog eventually dry up and go away or should I take it to Apple?
RoofMonkey
Jun 21, 2010
8,881
2,051
You could try re bag of rice trick. Place phone in a bag of rice, this will absorb the moisture. You probably don't need to as I bet the lens will clear on it's own but thats an option.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
I'd try like above, but if that doesn't clear up, then Apple! Because fog has some moisture in it.
Apple fan
May 31, 2010
244
Lutz, FL
I dropped my 3GS in a pool water leaked out of it put it in rice then sold it on eBay for 110. Just sharing my story. Anyways yes it will dry out. If battery life is not as good as before then it has partial water damage to it. Like major battery loss. I've heard stories of partial water damage and while you're raking out the trash and it gies din like 7%
