For those complaining about battery life...
crane98
Jul 11, 2007
121
You may want to consider buying this portable charger for the iPhone. It's only $7.99 (shipping is like $2.85) and it fits on your key ring. Mine just came in the mail yesterday. It seems to work pretty good. It's not a solution to the battery problem, but it's nice to have if your battery goes dead and you're away from home.
http://www.handhelditems.com/iphone-emergency-charger-p-7915.html
I already have a car charger-anything else would be ridiculous. The phone was suppose to have an 8 hour usage life, and the only way to achieve that is with brightness almost all the way down, no ipod, no internet, no movies. Maybe we should all carry a generator around with us so we can charge the phone.
DRabbit
Jul 2, 2007
383
I don't know what you're experiencing, but I've gone as long as 3 days without having to charge... typically though, I go 1 1/2 to 2 days. Yes, I browse the net (and yes, with WiFi on ONLY when I need it). Yes, I do e-mail. Yes I do texting. Yes, I make and receive phone calls. Oh yeah, and I listen to the iPod too.
What I don't do is use it like a laptop and expect it to last much longer than one.
RLK
81
Indialantic, FL
How many hours of use can you get from a battery. The web site has no mention of the usage times.
alb0zf1n3st
Jul 2, 2007
624
Not bad I was debating on whether I could buy one of these just to keep on the side incase
