Force a Backup Sync?
Michael Baturin
Jul 11, 2007
1,750
244
32
South Jersey
Hey. I haven't been in around in a while. I recently plugged in my iPhone and during a sync, I got a message saying Outlook could not find an Outlook.pst file. I didn't think much of it, but when I took my phone out, all my contacts are missing. I've searched my computer for *.pst and found nothing, then i went in and found a .pst file. When I open it with outlook there is nothing. No contacts like there used to be. I checked my backups from iTunes and there is one from a couple weeks ago that would have my contacts on it. Anyone know a way to force a sync to a backup file? The reason I don't just restore is I have 1.1.2 jailbroken by going through the 1.1.1 tweak called O something. If I restore, ill have to go back to 1.1.1 do that again, then go back to 1.1.2. and redo everything. Anyone help?
iFuNk
Oct 25, 2007
93
Hey I hope this helps ... In the preference tab in iTunes ... under syncing .. you can see all the backup files .... if you delete the more current ones ... it will backup to the one that has all of your contacts in it when you restore .... you can give it a try ... after all .. u don't have much to lose ...
hope this helps
Rip
Oct 23, 2007
636
Northern England
Alterntively, import the pst file that you found into Outlook, and sync as normal.
Michael Baturin
Jul 11, 2007
1,750
244
32
South Jersey
I restored and got my contacts back. Im looking into rebacking them up on outlook and how to do it. Thanks for everyones help.
