Forgot an app, and a question...
fz1dave
Sep 13, 2009
198
nw indiana
I'm looking for the app that quickens the animation, well doesn't actually quicken it I guess but it makes it appear that way. I've been looking for an hour in Cydia and can't find it.
My question is regarding the intelliscreenX page on the lock screen. Where it's supposed to show the weather and temp on top, all I'm getting is the word "Weather", nothing else. Doesn't matter what I hit and I can't find a way to change anything in settings. Any ideas?
5,578
I've never used Intellescreen, but the FAQ says it should automatically find your weather location. I'd just disable the Intellescreen weather widget if there is an option for it. Apparently, it only updates every 12 hours (to save battery), so it's fairly useless anyway. You can view the stock weather widget on the lockscreen if you install Bulletin.
fz1dave
Sep 13, 2009
198
nw indiana
I tried that already. Getting ready to ditch it. Sucks I paid for nothing though.
iphonewarrior
13,847
702
Forecast is a nice little weather tweak, which works on both the lock screen and Notification Center.
