Forgot iPhone 5c password
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
I searched but could not find anything on this.
My daughter forgot the password to her iPhone 5c. It is now disabled. There is conflicting information on the web about this.
What is the best way to recover the password, or reset the phone?
Thanks in advance.
28,365
5,506
Connect it to the computer it's synced with and restore from backup. If she backs up with iCloud, restore it on a computer and then apply the iCloud backup. If Find My iPhone is enabled, she'll need to disable it on iCloud.com before restoring.
28,365
5,506
Thanks Europa.
Can I disable find my iPhone via the website?
Yes, you have to log into iCloud from a computer and delete the iCloud account for the iOS device before you restore it in iTunes. To do this you'll first need to turn the iPhone off so it goes offline. Then go to iCloud.com, login and click the X next to her 5c. This will remove the device from iCloud and you can then restore it in iTunes.
