Forgot iphone lock
Discussion in 'iPhone' started by nacfield, Feb 17, 2008.
Thread Status:
Not open for further replies.
  1. nacfield
    nacfield New Member
    Hi ,
    I forgot the password lock (4 digit) .How can I reset it ?
    Currently I can access all the setting using the stack controller software that I installed.
    When I choose disable the password it will ask the old password again.
    Please help.
  2. CowboYZ
    CowboYZ Member
    Sync it with iTunes.
  3. Avatar
    Sponsored Advertisement
  4. Rip
    Rip Member
    I don't have this problem and it useful to know the solution.
    How does synching to iTunes help?
  5. nacfield
    nacfield New Member
    I able to sync with itunes but after that still require password to log in .
    If there any website I can access using the iphone and download the patch to reset the password.
  6. Lincoln
    Lincoln New Member
    Try a Restore, and don't sync from a backup. This will probably remove it. Note that any modifications you've made will be gone.
    - John
  7. nacfield
    nacfield New Member
    Hi John,
    Thank for reply.I able to log in already.What I do is I key in the passcode from 1000 onward then when reach 1100+ I able to get in. Lucky I can get in my iphone using one of the application installed.It hide on the right hand corner.you can access all the application by pointing on it.
    So I go to the setting and change password and keep key in the password until is unlock.
    Thank again..
  8. Alaimo
    Alaimo New Member
    so im an idiot and forgot my password to unlock my iphone. can anybody help with this? I don't even care if I lose all my information I just want to get back into my phone!
  9. Europa
    Europa Moderator
    Restore it as a new device (not from back up) in iTunes. After that, you can just sync your media and apps back onto it.
  10. citizenwp
    citizenwp New Member
    try this...
  11. BigCiX
    BigCiX Zealot
    Somebody correct me if I'm wrong but I think u plug it up to iTunes, hold down start and home button for 15 seconds. It should give u the option to restore your device
  12. iBurner
    iBurner New Member
    Just try restoring it as a new device.
  13. froudy
    froudy New Member
    hey
    I tried to restore but it wontwork.. and answers on how to fixthis
  14. Cjvdh
    Cjvdh Zealot
    These people probably stole iPhone's and are trying to get them to work. LOL!
  15. iNinja
    iNinja Zealot
    My thoughts exactly.
Thread Status:
Share This Page
