Forward No-Answer on AT&T
brojimh
Aug 1, 2007
142
Morris, AL
does anyone know how to set the forward no-answer on the iPhone?
I want to use a service that converts my voicemails into emails/text msgs. but you have to forward your phone so that instead of going to the AT&T voicemail it goes to this company's system.
I know how to normal forward but I need the forward no-answer.
Any ideas?
brojimh
Aug 1, 2007
142
Morris, AL
Any ideas?
Nevermind, I figured it out.
Just in case anyone else wants to know. . .
dial *61* then the number to forward to # CALL
This will allow calls to come into the iPhone but when you don't answer or are out of range the call will go to the desired number instead of the AT&T
voicemail.
ACTUALLY: Here is the entire list of forwarding options:
  • Immediate Call Forwarding: Dial *21* plus the 10-digit number to which your calls should be forwarded and #. Press Send.
  • Busy Call Forwarding: Dial *67* plus the 10-digit number to which your calls should be forwarded and #. Press Send.
  • Call Forwarding No Reply: Dial *61* plus the 10-digit number to which your calls should be forwarded and #. Press Send.
  • Call Forwarding Not Reachable: Dial *62* plus the 10-digit number to which your calls should be forwarded and #. Press Send.
