Freaking out a little bit
Banjo456
Apr 27, 2008
52
ok I don't know what I did but I can't install anything or uninstall anything youtube cannot connect what I'd wrong with my iPhone
Banjo456
Apr 27, 2008
52
I finally got SSH working and everything and now nothing else will work I know that there are fixes but I don't know what they are and I tried all of the youtube fixes and none of them worked
chcorey52
Dec 25, 2007
556
try refreshing community s==ources and turning on airplane mode
Banjo456
Apr 27, 2008
52
tried both with no result when I turn on airplane mode it doesn't help in any way at all
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
What jailbreak method did you use? After this amount of time, honestly a restore would likely be a quicker solution.
If you do go for a restore, it is important to choose to setup a *new* partnership with iTunes, not restore from backup - so make sure you have all your contacts / photos etc. on your computer and can sync them back afterwards ...
Banjo456
Apr 27, 2008
52
I used ziPhone and if i restore clicking on new partnership what does that do exactly
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
If you're using ZiPhone I think you may want to make sure you use one of the 2.5 (a,b,c etc.) versions of it, rather than the current 3.x versions. I've heard 3.x is more problematic.
New partnership just starts fresh in terms of the sync partnership between the iPhone and iTunes - it does not restore back any settings etc.. It does NOT mean you need new activation or anything contractual - it's just a new sync relationship and doing this has been known to get FAR better results for most folks ....
Banjo456
Apr 27, 2008
52
how to I check which ziPhone version it is and does that effect the restore
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
As soon as you launch the app, it should say in its status bar (for Version 3 anyway) what version it is. It also shows you the version number when you click the download link at the ZiPhone site.
Not sure what you mean by 'does that effect the restore" - but if you mean should you still restore as a new partnership rather than restore from backup, then yes - do that regardless of which version you run ...
