Free or unlimited text between iOS 5 users?
Jwp449
Oct 24, 2011
I currently have an iPhone with iOS 5. Is text messaging free between iOS 5 users? How can I be sure my carrier is not charging me when I send a text to another iOS 5 user?
Booyow1204
Jul 14, 2010
595
40
Las Vegas
iMessage won't count towards your text messaging plan, but it will use up data on your data plan. Depends on the package you have, if you go over your data limit then it's not free.
rambo47
Apr 4, 2010
528
79
Northern NJ
To use it you need to have the other person's mobile phone listed as "iPhone" in your contacts. Then text messages default to iMessage.
Lon
Jun 5, 2010
2,946
132
Alaska
I have someone who's phone is not listed as iPhone and it goes through iMessage. ?
None of mine are listed as iPhone and they all work. I quit using iPhone label because they synced to Outlook as "Other" which created duplicates.
(L)
Nov 7, 2010
277
Arizona
The other device has to be running iOS 5 in order to be sent as an iMessage.
rambo47
Apr 4, 2010
528
79
Northern NJ
Awesome! My texts to my son's iPhone didn't go through as iMessage until I changed his contact to reflect his iPhone. But if it works automatically that's super!
FuelieNova
Aug 3, 2008
636
33
I thought I read some where that if the text goes through iMessage to another iPhone ios5 the text bubble is blue. If not it is green.
Tom
raziiq
Jan 27, 2009
Tom
Yes that is true. If msg is sent using iMessages, its blue, if its a SMS its green.
AeroCare
Jul 16, 2009
1,210
25
All over the World !
One thing you might want remember, iMessage is free IF the Apple servers are NOT BUSY. If they're busy it'll go through the cellular carrier and you will be charged for that text if you don't have a text messaging plan. That's why for my normal texting I use Google Voice which is always free and I use TextNow for all my texting when I'm outside of the USA because it's also free and also has picture texting..
RoofMonkey
Jun 21, 2010
8,921
1,983
Yeah I think it only ha to be running ios5. Don't think it matters about how it's listed.
That's what I thought so I changed a couple just to check. Still showed as blue. I have had them go through as regular though. so like AeroCare mentioned I guess it is dependent on Apples servers.
JDem
Jan 19, 2011
265
27
NNJ and Central PA
Am I missing something, I know it has no bearing on iMessage, but I just checked and I no longer have the ability to label a contact as iPhone. Anyone else see this in iOS5?
JDem
Jan 19, 2011
265
27
NNJ and Central PA
Not there for me bite...I figured it out, its cause of google contacts. I synced all my contacts with mobile me instead and its back. Thanks for lookin brooklyn
alone979503
Oct 25, 2011
Hi team
What is the different if I am using Whatsup app for sending messages between our friends and Imessage
What is the advantage between two
JDem
Jan 19, 2011
265
27
NNJ and Central PA
Hi team
The difference is Whatsapp is telephony based so it will not work on "WiFi only" type devices like Ipods. It is associated with your phone number.
KevJD
Aug 30, 2008
168
Not if you turn off "Send as SMS" in the settings. This way, it will not default back to regular SMS if the servers are down.
