froze while installing ziPhone
Sep 12, 2007
14
i didn't restore ipod before using ziPhone and while it was loading ziPhone, iTunes had a screen that said ipod is in recovery. i clicked ok then exited iTunes. then my ipod froze. after 3 minutes i cancelled ziPhone and disconnected ipod. now its frozen. it wont do anything and computer doesn't detect?!?!?!?!?:mad::oops::mad::mad::(
Sep 12, 2007
14
i held down the home key and sleep button and it turns off. i can hold down the home key and it will turn back on but it just goes back to the white words and the computer still won't detect
tariqmirza
Dec 18, 2007
Once you have done that you should have got an image of itune and a cable connection, then you have to connect to itune and do a restore, once you have done that you can ziPhone it again
