frozen and missing icon
iNurse
Nov 11, 2011
559
The Volunteer State of Tennessee
Help.. I have jailbroken 4s. It has been working awesome. Today I was messing with Srpingtomize. I have lost my dialer and contacts... Rebooted a few times checked settings..... now I phone icon back. No contacts. Now it keeps freezing....... please help ...(I have springtomize and winter board loaded)
RoofMonkey
Jun 21, 2010
8,924
1,983
Have you tried a hard reset? Pressing both home and sleep buttons, ignore the slide to power off. Rlease both when you see the Apple logo.
RoofMonkey
Jun 21, 2010
8,924
1,983
Hmmm... I haven't used used springtomize so I'm not sure here, but is there a way to hide icons with it? Installed any themes in winterboard?
Just thinking that you may have to either remove them one at a time to find the possible rouge theme, or remove any and all and start reinstalling one at a time. :(
Can you access the Contacts app through Spotlight? If so, check to see if it is hidden through SBSettings.
SBSettings > More > System Wide Options > Hide Icons > Contacts > On
It's a Cydia app. So I'm assuming you don't have it installed.
I've never used Springtomize. I've heard it's buggy. Can you hide apps through Springtomize? If so, reinstall it, see if you can unhide the app and then uninstall it. Otherwise, just access it through Spotlight.
No. They won't disappear. You could try that, but I'd try unhiding it with Springtomize first.
You could still try reinstalling it, hiding it, then unhiding it and seeing if it comes back.
iNurse
Nov 11, 2011
559
ok will do.... may head to bed.. Will report back tomorrow.. Thanks Europa for your time in trying to help me! :) This didn't start until today when I was watching a video tutorial on springtomize and was trying to follow along with my iPhone ...
