Frozen banner
15,385
1,089
Is this here to stay? I don't care for it - it eats up a ton of space in my web browser.
edit: I've switched to the mobile theme for now...
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Not sure. I'm listening to feedback and will make adjustments based on that.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Out of curiosity, what computer/resolution/browser are you using. Care to attach a screen capture.
15,385
1,089
15" MBP, 1440x900, safari. It would be even worse if I wasn't a side-docker.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
At some point, I'll have a solution for you, but I cannot implement it just yet. Once I freeze the code on the main template, I can offer an option to members to select the same theme, but without the locked navigation.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Are you seeing solid blue circles where my avatar should be? If so, are you running some plugins that would block images from loading?
15,385
1,089
no worries, mobile template seems to be working fine.
15,385
1,089
yes, solid blue for you, but others' avatars look fine. only blocker I'm using is glimmerblocker.
