Fuzzy Screen Issues from Bodyguardz
massyman
Jul 15, 2008
43
I tried installing Bodyguardz on one of my new 3GS's. After an hour, I gave up. It was a pain to do the back side of the phone. The front was simple, however, after stripping the phone of the Bodyguardz it seemed as if the screen was not nearly as sharp anymore, sort of fuzzy in a way. I am assuming it was from the spray application that was on the screen. Anyone else run into this problem?
vrsc
Jun 22, 2007
204
Orlando, Fl
Yes, it's a pain! The backs the worst. Your screen won't ever look exactly the same with any screen protector. They have the advantage program that you can send the used ones back and get a replacemet for $4.95
nbviper
Jan 20, 2009
112
MA
I have had bodyguardz on my last 5 phones, including my 3G and current 3GS. I guess practice really helps when installing these things. My covering went on perfectly the first time this time. All I can say is use lots of spray, a hairdryer to help cure the edges quickly, and follow the tips that bodyguardz gives you as far as lining things up.
