Galaxy 2 Skyrocket
Nur2652
Aug 1, 2010
114
My iPhone 4 is crapping out on me and failing me more and more everyday. It'll be 2 years old in June. I don't know anybody with a Galaxy, but I hear it's AWESOME. Any info or thoughts on the Galaxy 2 Skyrocket? Thanks.
Christopher Meinck
Administrator
Administrator
Sep 13, 2008
89
23
If you don't have 4G in your area, then you might want to consider the S II.
Make sure you purchase it at a place where you can return it for an iPhone.
  • Like
Reactions: Bennyboy
theorioles33
Jul 21, 2007
925
135
USA
The problem with all these new phones that are coming is that they run Android. Stick with iOS. You can stray but I suggest you save your money and just stick with the iPhone. I've been there. Spent hundreds on Android and Win7 phones only to come back. Never again! :)
  • Like
Reactions: Shax
Nur2652
Aug 1, 2010
114
Yeah no 4G in my area. Or maybe I do. But I was told by Apple that only the iPhone 4S could get 4G, not the iPhone 4.
ZR_Yancy
Jul 11, 2008
3,982
737
iPhone 4S doesn't have a 4G radio.
I have a Skyrocket and it's ok. It's fun at first because customizing can be done but that wore off quickly with me so I now just use my iPhone 4S. If you want to play with a Skyrocket, get the Skyrocket HD.
Apple iAddicted
Feb 20, 2012
269
27
I had a galaxy s 2 a month before i got my iPhone4s in in fact gamaxy s 2 is why i switched, before that i was a dedicated Android junky. Anyway i tossed the 2 1/2 week old galaxy 2 on a table had a gel skin on it and the screen shattered across the top. Problem was in the construction of the casing the screws go in little tiny metal rivits on a plastic frame the screen cracked right along the line of screws, now unlike iPhone the Androids don't work with busted screens. They are making their screen too large and casing too thin, if you get an galaxy 2 buy an otterbox right with it or the least little bump in the right spot will shatter your screen and you will either be doing insurance if you have it or crying over a busted phone that is crap. And this is from a guy who used to be so dedicated to Android i had the droid kills iPhone ringtone and an Android smashing a iPhone back grownd. Stick with iPhone i learned the hardway lol
