Gaming iOS or Android
iDapzZ
Aug 25, 2014
45
Ok so I've been toying getting rid of my plus and getting a note 4 but from what I gather gaming is better on the iPhone than android.
Is the ram not starting to change this.
And if gaming is better on this how comes pc gaming is apparently far beyond Mac.
Just curious so someone more intelligent can educate me
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Have you looked at the games available in the Google Play Store as compared to what's in the App Store. There is no comparison. If you are serious about gaming, the iPhone 6 Plus is the better option. I'd recommend looking at your top 5 games. Are they available on Android? If you switched, what you be missing?
Santa
Jul 2, 2009
1,122
115
Colorado, USA
Yep. Although I was tempted to jump to Android land this time around, one of the reason I stayed with the iPhone is that there seems to be near universal agreement that the app experience (especially games) is better with iOS. Partly unified hardware. Partly the OS. Partly market share.
Re. the RAM. I don' think that's going to be a problem running a game. It may be a problem pausing the game, jumping to email/Safari/..., and going back to the game. It's more likely to get swapped out with only 1Gb.
iDapzZ
Aug 25, 2014
45
I don't really no if it makes a difference ram.
All I no is when I watch videos the iPhone's are always good looking and smooth and android are a bit laggy here and there.
But I wonder with the huge specs on android if their going to push beyond the capabilities gaming wise of Apple that's pretty much what I should I asked in the first place lol
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Having used a variety of Android devices, none have been able to replicate the buttery smooth performance of the iPhone. I heard one report that Lollipop is a big improvement, but reserving judgment until I see it.
I swear this RAM thing is going to keep the allies from winning the war.
This isn't going to help.
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
Big numbers on a spec sheet don't always tell the whole story. You really can't compare numbers from different hardware/chips, etc. Hardware/software integration is a big consideration as well.
iphonewarrior
13,847
702
We all know how well (and how bad) iOS runs (most of the time), another thing to consider... how would iOS run if given top spec Android hardware? It would probably be all kinds of awesome, but hopefully without the cheap plastic ;)
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
On the other side, how well would Android run with better hardware/software integration and optimization?
Sep 22, 2014
Games should work quite well esp the latest generations. How much less would the battery last with more ram? ... Apple is NOT throwing stuff into their devices like android and it seems we have a well balanced configuration.
raqball
Jan 30, 2011
1,079
199
So. California
Against my better judgement I am going to jump into this one..
RAM does matter..
Lets say you are close to maxed out, I posted screenshots in another thread on this, at boot. Now you open several apps and let them run in the background. Sure iOS does a stellar job of managing it's limited resources, but.. Now you open a game and perhaps this is a game that uses a lot of RAM. What do you think happens to all the apps and processes running in the background? Well, iOS will shut them down to make room for what the game you are playing wants..
Is this a mega problem? Well it could be depending. Then again it could be meaningless. It depends on your usage.
Anywho, If I were a big gamer (I'm not and have one game, Letterpress, on my phone) I'd probably go with an Android device that offers more than 1GB.
I will now go stand in the corner with my dunce hat on.. :p
iDapzZ
Aug 25, 2014
45
So basically iOS is the much better phone for gaming but if multi tasking is crucial more than 1 ram maybe necessary i mainly use my phone for text. Facebook Twitter and games so I guess this is ideal based off that
raqball
Jan 30, 2011
1,079
199
So. California
I am going to quote what is the best advise given in this thread.
Have you looked at the games available in the Google Play Store as compared to what's in the App Store. I'd recommend looking at your top 5 games. Are they available on Android? If you switched, what you be missing?
^^^ What he said! ^^^
If all you are doing on your phone is gaming, texting, Facebook and Twitter then the iPhone will be fine as who cares if iOS temporarily shuts Twitter down...
Njshoremom4gurlz
Sep 13, 2011
536
84
I found apps crashing on android even silly candy crush lol
rom x
Jan 18, 2011
1,043
99
In all fairness I get more app crashes in iOS than on current Androids running 4.4.4.. I get zero, nadda, zilch for crashes in Windows Phone 8.1..
as far as crashes i find both android and ios about the same. but no doubt when you JB the iphone and root the android. the iphone then becomes a a daily crasher compaired to android. your mileage may vary:)
diverdown
Sep 12, 2007
970
49
NYC
All of the games I play are on both iOS and Android. My Z3 plays games just as smooth as the 6+......
~S
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
My mileage definitely varies from yours. No crashes on my jailbroken iPhone.
Feb 3, 2013
190
I prefer using android in gaming because many cheap and budget friendly android device has a good GPU.
