Garage Band and "protected files"
Atlas
Oct 14, 2007
88
I tried using garage band and get this prompt telling me that protected files can not be converted with aac?
All of my music is from iTunes or my own cd's. Why can't they be converted with garage band or the other way in the 1.1.2 update.
PS i am importing songs through aac in iTunes, should I be using Apple Lossless or some other seting when I put songs into iTunes?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
What I do is play the song and record it in my soundforge program, then do what I want.
Atlas
Oct 14, 2007
88
"soundforge" ?
Do I need to jailbrake for that? So far I have been afraid to modify the phone. It seems others have been doing it with the 2 methods I've tried without difficulty. Just not sure why mine won't.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
"soundforge" ?
No that software is on your computer. You record it on your computer and then use for what ever your need is such as ringtones, then import into iTunes to put in the ringtones folder.
