GBA Emulator
Pharaoh
Sep 7, 2007
91
I did not see a posting of this, sorry if there is one
I noticed there is a GBA (gameboy advanced) emulator, which is AWESOME, one problem is when i put the games in there (like the NES emulator) but then it says i Need a BIOS, how do I put a bios in the folder in order to run these games and where can I obtain one?
Sep 29, 2007
348
Can you send me a link to the emadulator? Posted from my iPhone .
wildonrio
Jul 4, 2007
2,002
Provo, UT
LOL. You two are funny. "emadulator"? Go to Installer on your phone, if you have it. It's called "gpSPhone" (for some reason). Here are directions I got from another post
1. Install it from installer.app (under games)
2. Install fugu on your computer
3. search gba_bios.bin on google and click on the first result
4. Go to settings on your iPhone, then general, auto lock and set it to never
5. Go to settings, wifi, click on the blue arrow next to the wifi service your using then write down the ip address
6. Open fugu and do the following:
Put in your iPhones ip address, for username write root, press connect, then wait a little while, then for password put in alpine
7. At the to click on the hard drive sign then go to applications/gsphone and drag the gba_bios.bin file into it
8. Download roms from romsite.net
9. Then create a folder under media called Roms the on named gba
10. Put the roma into gba folder through fugu
11. Then open the emulator, press the start button, use d pad to go to load new game and use the b button (which is a), make sure the 2 dots are highliged in white then press b, and then the 2 dots again, then select VAR, then root, then roms, then gba, the use the d pad sideways to choose your game, then select it by pressing b
12. Then play your game! The buttons are kinds messed up (like b is a) but just figure them out yourself
Have fun!
Pharaoh
Sep 7, 2007
91
fugu seems to be a mac only program
i use pc
any help with pc? i really wanna get this to work, thanks
Pharaoh
Sep 7, 2007
91
ok gba emulator just updated, I downlaoded new version, you no longer need to do that step with the gba_bios.bin
Although it froze my iPhone my first time loading a game..
Pharaoh
Sep 7, 2007
91
edit: and everytime I tried after, anyone else used this software successfuly?
Tinman
4,334
183
Aridzona
Remember that step you thought you didn't have to do anymore? Well you still have to do it. Without a valid copy of gba_bios.bin placed in the game's folder it won't--can't--work.
Mike
Pharaoh
Sep 7, 2007
91
so how do i do it then? like i said that FUGU is a mac only ap isn't it? if it isn't, then I don't have a software to run it, its an unrecognized file type
Tinman
4,334
183
Aridzona
Assuming you can't use SSH/SCP, download iShare from Installer, upload the file on your Mac using SendSpace.com, then download it to your iPhone using iShare--placing it in /Applications/gpSPhone.app.
Mike
Pharaoh
Sep 7, 2007
91
Mike
i do not have a mac
Jul 21, 2007
19
This program is available via installer. No need for ibrickr (except for ROMs.)
musicmanmu
238
WV
Not true - you can upload GBA ROMs to SendSpace via your Mac or PC, then download them to your phone via iShare. Even on edge, it only took about 4 min. to download a 4MB GBA ROM. Not too bad...
Jul 21, 2007
19
I wasn't implying the only way to get ROMs onto the phone was via iBrickr.
What I WAS implying was that iBrickr is not the ONLY way to install the app.
Tinman
4,334
183
Aridzona
Why would you think anyone thought iBrickr was the only way to install files? I didn't get that impression.
Mike
Jul 21, 2007
19
Mike
Quote:
Originally Posted by colombianito
get iBrickr
i just tried it with ibrickr, browsed applications, a bunch of applications were on there (most I don't even have) but no gpsphone ap.
