Gba4ios
bulls6pack
Jan 27, 2009
154
Peoria, Illinois
Gba4ios, for those of you who aren't familiar with it, is a downloadable Gameboy advance emulator from the website, that allows you to download Gameboy roms onto. I had it, and was able to play Mario games and many more on ios7. Since upgrading to ios8, it is no longer working. I deleted it, and tried redownloading it to no avail. Anyone else with the same problems? Suggestions?
fsas06
Oct 15, 2007
604
Las Vegas
when you downloaded it did you set the date back 24 hours ? i have it on my 6+ so it does still work. try setting the date back before you open it, then after setting the date back open the app once and set the date back to normal
fsas06
Oct 15, 2007
604
Las Vegas
if your still having problems the creator has a reddit here http://www.reddit.com/r/GBA4iOS/. looks like some others are having the install problem, you can message Riley on reddit or i think his twitter is on the sub info
bulls6pack
Jan 27, 2009
154
Peoria, Illinois
Thank you. Yeah I had it on ios7, and it worked great. When I updated to ios8, it wouldn't open, so I deleted it, and thought I'd try to redownload it. No luck. I set date back a few days, and the newest version, 2.0.7, I think wouldn't do anything. I even tried the older version, 1.6.2. Now it actually loaded but would never open.
