Genius bar told me after market charger won't charge iPhone properly
apple718
May 27, 2009
121
Today i went to the genius bar because my battery was dying fast. He asked me if i am using an original Apple charger or an aftermarket charger. I told him after market and he told me that's why my battery is dying because it doesn't fully charge the iPhone.
Was this a line or is it true?
Adam1389
Nov 20, 2008
588
Ilwaco, WA
As long as its putting out the correct voltage and amps, it shouldn't matter if its aftermarket or not.
psylichon
Oct 31, 2007
16,591
751
41
Philly
How "aftermarket" are we talking here? Did it have a "made for iPod" or "made for iPhone" logo on it?
apple718
May 27, 2009
121
it has a sticker that says "for iPhone 3g"...lol
my usage times are:
Time since last full charge
usage: 0 mins
standby: 0 mins
call time
current period 1 hour 55 mins
lifetime 1 hour 55 mins
cellular network data
sent 8.4MB
received 118 MB
i have the phone currently on charge as i read these usage times to you...
should i just keep it on charge even if its full?
Adam1389
Nov 20, 2008
588
Ilwaco, WA
It won't hurt anything to keep it plugged in, the phone will cut the charge off when its full. Go as long as you can using the phone like normal and post your usage data here again. There might be a few changes you can make to save your battery life.
apple718
May 27, 2009
121
ok so since my last reply which was like a lil over an hour ago.. since then i took it off charge i downloaded 2 games and played them both for a little here is my usage.
time since last charge 1 hr 27 min
stand by 2 hrs 7 mins
call time the same as before
sent 9.0MB
received 131MB
there is some battery gone already...is this normal? do you think the charger plays a role?
apple718
May 27, 2009
121
also just a little about my settings
push data is off
fetch is on 30min
location services is off
3g is off
wifi is off
screen light it set to about 10%
Neo-Tech
Oct 24, 2008
254
Woah! Your battery should be lasting ALOT longer if you've turned off most of the power hungry features. Try a normal charger or the USB port on your PC/Mac.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
With 3G on, Push on, and fetch at 15 minutes, brightness at about 1/4, I am getting about 5 hours of usage, and maybe 8 hours of standby, that gets me down around 10%
apple718
May 27, 2009
121
so what do you guys/girls say should i buy an original Apple charger or should i go to Apple store and tell them to fix this problem.
apple718
May 27, 2009
121
ye i did that before and its the same thing.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Same as with the aftermarket charger? Then it sounds like the charger is fine, your phone battery is in need of replacement. When you go back to the Apple store, tell them you are using an Apple charger this time ;) They won't know the difference.
apple718
May 27, 2009
121
lol ok thanks .... he also said he was going to try and restore my factory settings but then asked about the charger...do you think i should restore the phone to factory settings?
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Just tell them you have restored it, the guy I talked to kept wanting to, but I told him I did a couple times with no change, he finally checked it off his list of things to do ;) Do a good backup though before you go in
apple718
May 27, 2009
121
ok thanks Adam i will go...and let you know how it goes.
apple718
May 27, 2009
121
ill be going tomorrow but just to tell you the battery already has the first bar gone...and i took the phone of charge an hr ago and wrote a few text messages .
