Getting songs from iPhone to empty iTunes library
iCop
Jul 7, 2007
87
Tucson, AZ.
I had to format my HD and somehow forgot to save my songs. Lost them all. Now I am trying to figure out how to get them from my iPhone back on to my computer. I am sure this has been asked several times before, but perhaps I am using the wrong search terms.
Help anyone?
geordisjd
2,442
Help anyone?
Yep, search for Tansee iPhone transfert software and be ready to spend a bit of money. If you're on a PC.
iCop
Jul 7, 2007
87
Tucson, AZ.
Thank you, I will check it out. Sucks that it isn't as easy as drag & drop :)
gcvt
Jun 21, 2007
1,029
San Francisco
I agree. Drag & Drop would make all our lives a lot easier.
Hope you get all your music back!
kwan
Jul 7, 2007
88
i think there might be a way. Theres a third
party iPhone software that let's you sync to two diffrent computers. This computer you reformatted could be considered your second CPU.
check out tune swap on iPhone.exploit.org/pxl
clausenfan
Aug 24, 2007
66
same thing happened to me, i used copypod. just type it in on google. it has a free trial of 100 songs at a time which i used and uninstalled and reinstalled it about 10 times for 1000 songs. If u have a ton of songs i think it costs 15-20 dollars to buy. works with videos to!
Good Luck
