Gmail and iPhone - how to NOT sync fully?
crash41
I like my non-gmail accounts b/c i get the emails and can read/delete/etc and it won't affect the email on my computer.
When I read/delete my gmail emails - they are read/deleted on my computer.
So basically i do NOT want my gmail fully synced. Is that possible?
psylichon
Oct 31, 2007
16,591
751
41
Philly
I think so. Just disable IMAP support in Gmail's settings on their website, then set up your iPhone to access Gmail using POP3 (you will have to set this up manually, not using the Gmail template that comes with the phone)
crash41
THANK YOU! That does the trick!
usanaples
Dec 18, 2008
Wait a second...
Its funny you say that because I would like to be able to delete the messages, because if I don't it seems they keep coming back until I delete them on my computer. If I read it on my iPhone (3g) and delete it, I want it deleted from gmail to...but it doesn't... how do I get it do do that?
Swagger
Jul 9, 2007
2,076
Fort Lauderdale, Florida
web.me.com
You need to go into Gmail settings and enable IMAP (Interactive Mail Access Protocol). You also need to erase your current Gmail settings on your iPhone then set up the new iPhone Gmail settings provided to you in Gmail settings for IMAP. The tutorial walks you through step by step how to set up Gmail IMAP on your iPhone...Mark
usanaples
Dec 18, 2008
Thank you for the prompt reply. Does having both POP and Imap enabled screw this up? I use the Pop for Apple Mail, and the imap for the iPhone...
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
thats how i am. i rather delete once and get'er done.
