Gmail downloading error
doron
Apr 17, 2007
1,141
tampa, FL
i opened an email in my gmail accnt and it opened the msg as usual...i closed it, and put the phone in standby...i went back to the msg, opened it and the msg said This message has not been downloaded for the server.
...any suggestions?
...and then i just got another error msg.
Cannot Get Mail
The user name or password for "pop.gmail.com" is incorrect
doron
Apr 17, 2007
1,141
tampa, FL
iPodZone said:
Doron, I know you might have tried this already but just in the event you have not it sounds to me you are having problems connecting to the Gmail server. 1 Check that your wifi connection is workings. 2. Check your Gmail POP Settings go here https://mail.google.com/support/bin/answer.py?answer=72454 this will give you a detail instructions on setting up your gmail account for iPhone. What I suggest is that you delete the current POP settings Account and start over with the instructions provided. I hope this really solves your problem
thanks...let's hope so...i'm not sure if its an edge issue or what...i don't have a wi-fi connection so i'm going to do what you suggest...
