Gmail will Reicieve, won't send
djf1530
Dec 4, 2007
first, i use an @businesss.com for gmail not @gmail.com
I followed the set up on google for setting up this kind of account. I can receive all my mail, but when i send it says "unable to connect to smtp.gmail.com"
Anyone know how i can fix?
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Are you connected using Edge or WiFi? If I am using my WiFi at home with a cable connection I cannot send using smtp's for other email providers. Likewise, when on Edge and want to send through my cable email account I have to use the cwmx.com one to send since I am not authenticated through my home internet provider. Perhaps this is the cause in your situation?
thesaint
Jul 9, 2007
341
DFW
Are you using POP or IMAP? If using POP, why not use IMAP? You don't have to be worried whether you are on Wi-fi or Edge.
termleech
Sep 7, 2007
1,154
McPherson, KS
Did you make sure to set up that the SMTP server requires authorization? Most (including GMail) require you to authenticate to prevent spammers from using them as an open relay.
