Google Calendar and Contacts not syncing
AgentX
Dec 2, 2011
24
Charlotte-North Carolina
Man, I've tried everything andI can't get all my folders to show up in imap gmail.
None of my contacts sync and no calendar. I know i have something screwed up in my google account that is blocking the sync.
I can't even find Mobile settings on my gmail or calendar settings:
http://www.google.com/support/a/bin/answer.py?answer=1736690
I'm lost can someone help me out from Google side? Is there something I don't have access to?
I do have my old n78 setup for mobile access but I can't seem to find where or how I did that.
Any help appreciated.
AgentX
Dec 2, 2011
24
Whatever I did in my google account, now in calendar on iPhone 4s I don't even have a button in upper right for "Calendars". When I turn Calendar "Off" in account "Calendars" button in iPhone calendar shows back up, but for local folders of course.
AgentX
Dec 2, 2011
24
Ok, set this up as exchange and it only synced 25% of my contacts. Calendar didn't really sync either.
Now I just need to get all the contacts synced, I'll deal with Calendar later.
How do I get all my contacts synced from google?
AgentX
Dec 2, 2011
24
Ok, whatever. I turned contacts off then on again and it synced all 500 contacts. Thanks.
The calendar is only showing my main gmail calendar, all my others are not in Calendars list. When I follow this:
www.google.com/support/mobile/bin/answer.py?answer=139206
in Sync folders it's saying it will only allow "1" calendar sync and I am not able to check the boxes of the other calendars from Safari.
Any ideas? Must be some setting in google account?
Edit: I was able to select from m.google.com/myaccount all the calendars for sync, but when I go into iPhone "Calendars" only the main xxx@gmail.com calendar is there.
