Google Calendar
Aug 20, 2007
Hi All,
I just made the move over to the iPhone... My last phone I was able to sync my Google Calender with my phone's Calender....
Is there away to sync my Google Calender with my iPhone Calender...
Thank you,
John
Quake97
Jul 10, 2007
522
Philly Burbs
Not on the iPhone, no. If you have a Mac, there are apps out there that will sync your GCal with iCal. Then you can sync it with your iPhone. Yeah, it's convoluted, but it works. If you have a PC, then I have no idea, but I'm sure there's something out there that will sync your GCal with Outlook.
Joe
toss002
Mar 7, 2007
Hi All,
Thank you,
John
Technically there is a way:
1) Go to this link, and read the comment by "josef" (right after mine "toss002"):
http://www.switched.com/2007/07/05/sync-your-iphone-with-google-calendar/#comments
2) By following his instruction, you will be able to see your Google Calendar on your iPhone's Safari--with just ONE click.
3) Now, to sync your data you need mobileGCAL:
http://www.mobilegcal.com/
There you go.:cool:
