GoPhone - Upgrading Text Plan
noho_2003
23
I signed up for the $59.98 GoPhone plan last week and I'm sending more text messages than I thought. So I'm thinking about adding the $4.99 feature for 200 messages.
Does anyone have this feature activate on a GoPhone plan? Does the notice of your remaining balance go away? I'm talking about the "annoying" message (I'm actually getting used to it, but I wouldn't mind getting rid of it!) that you get everytime you send or receive a message and that lets you know you spent 15 cents...
Sep 12, 2007
14
how much $ are each of the text plans?i was told unlim. is $20!
noho_2003
23
i think there are only 2: 200 text for $4.99 or unlimited for $19.99.
Sep 17, 2007
text
I have that same exact plan, and I added the 200 message plan, yes it still gives you that popup but it says you have used $0.00, until you send over 200 messages then itlll start again with the $0.15
noho_2003
23
tricky AT&T! thanks for the answer though :)
htech
Jul 27, 2007
35
Really? I don't get any pop up messages. I added 200 when I signed up. I only get a balance notification when I end a regular phone call.
noho_2003
23
Maybe if you add it when you sign up it's different from when you add it later on? Meaning, if you add it at the sign up you won't get the messages, while if you add it later you will? Just a thought...
damstr
Jul 2, 2007
133
Can you upgrade your text plan online or did you half to call them? I got the 200 text message deal but want to upgrade to unlimited.
