got a big problem here! cant downgrade!
jackie91
Jan 31, 2008
i accidentally update to 1.1.4 which it cant jailbreak yet but i try to downgrade to 1.1.3 it show error during restore......
any idea ? i do it with press on shift restore and it run half way it show error!
thank you for advise !
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
What is the error that is shows? Also you can jailbreak 1.1.4 using ziPhone (although it is not officially recommended), just not all software will work yet.
paddy130
Feb 29, 2008
IM HAVEING SAME PROBLEM HAD ALL WORKING BUT SIM AND DID THE SAME THING ERROR 1015
HAD YOU ANY LUCK
paddy130
Feb 29, 2008
downgrade
had you any luck fix if you do let me know thanks
Bone
Feb 11, 2008
1,214
I'm reading reports that ziPhone will jb a 1.1.4 now. But as always you should remember its at your own risk.
jackie91
Jan 31, 2008
still not yet ! i did read the ziPhone can jailbreak 1.1.4 but with 1.1.3 firmware in it ... but if our phone without that firmware it wont work using ziPhone
