Got CallD to work...somewhat...
Jun 7, 2007
545
Queens, NY
if your a person that needs CallD to work on your 1.1.3 jailbroken iPhone using the ziPhone method...well...it doesn't launch...it just opens and crashes....well if you really need to use it, its best you get familiar with
term vt100, cause for some reason it opens when you launch it from the command line...anyways...
open term on the iPhone type #/Applications/CallD.app/CallD
yes the capitalized letter are a must for some reason.
some people have reported on other forums that calld does work with 1.1.3. but they were using the softjailbreak method.
update: also wetool-us does work using the same command line..but only to delete recent calls....
#/Applications/weTool-US.app/weTool
also, make sure you have BSD subsystems installed, with BSD subsystem 2.0 termfix
services install and service.app SUID fix
SUID lib fix
term-vt100 SUID fix
source is http://www.trejan.com/irepo
thanks to callae from modmyiPhone.com
ps. i know it seems like a lot..but for now, its better than nothing....
Jun 7, 2007
545
Queens, NY
SUID lib fix
term-vt100 SUID fix
here is the correct way to make callD actually work thanks to tinman for this...it also makes wetool-us:
For starters you need to delete the following folders, should they exist (pay CLOSE attention to their location--they are in /var/root):
/var/root/Library/AddressBook/
/var/root/Library/CallHistory/
/var/root/Library/SMS/
delete those folders then:
Then execute the following commands:
ln -s /var/mobile/Library/AddressBook /var/root/Library/
ln -s /var/mobile/Library/CallHistory /var/root/Library/
ln -s /var/mobile/Library/SMS /var/root/Library/
winscp into the iPhone and open the teminal...copy and paste the three commands hit execute and when your done restart the phone...and callD and wetools-us will work...
ziPhone jailbreak method..
thanks again tinman
Feb 16, 2008
I am a big time iPhone n00b (2 days) so this question will definitely sound elementary. Here goes...
How are you getting to the file structure to even delete these folders.. Are you doing this while connected to computer or an iPhone app?
How do you do all of this? "winscp into the iPhone and open the teminal...copy and paste the three commands hit execute and when your done restart the phone...and callD and wetools-us will work..."
thanks again tinman
