Great screen cleaner
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
I've been using the iCloth that came with the iPhone, and also a microfiber cloth that came with my shades, and these have done a good job of removing 99% of the grime, and keeping the iPhone screen scratch free.
However, there was always a little bit of grease left on the screen, no matter how hard I tried to clean it :(
So today, I tried Glass Plus wipes on the iPhone screen
Amazing!
Back to 'as new' in seconds, no grease, just a nice streak free clean.
Using the wipes avoids any issues spraying liquid cleaners onto the iPhone, and they are available everywhere, with great prices at CostCo.
bsharp
Jun 21, 2007
351
Atlanta, GA
Amazing!
Thanks. Great idea. I've been wondering how to keep the screen clean.
I use iKlear, sprayed on a soft cloth. Your solution sounds better.
xoulo
Jul 9, 2007
323
awesome. but i rarely clean my screen unless its really really dirty:p
pxlfxr
Jul 21, 2007
Glasses wipes are great to
The little foil packed alcohol wipes for eyeglasses work great and very portable.
pharoh
Jun 28, 2007
35
Amazing!
I shower with mine...cleans the screen and case too...
Joon
Jul 14, 2007
214
I don't know the specifics on this stuff, but I know window cleaner has ammonia(or something else in it) that is not good for LCD screens or plasmas. I don't know if it will apply with the iPhone, but I would stick with dry cloths or something similar to iKlean. Let me know how you guys like these wipes, cause if they are working I might pick it up at a later date.
Alexander
Jun 28, 2007
1,724
Atlanta
Keeping in mind the iPhone screen IS glass, I wouldn't personally compare it to a LCD. However it's true the only APPROVED cleaner is what is sold by Apple.
robtob
Jul 17, 2007
From the iPhone user guide:
Keeping the Outside of iPhone Clean
To clean iPhone, unplug all cables and turn off iPhone. Then use a soft, slightly damp, lint-free cloth. Avoid getting moisture in openings. Don't use window cleaners, household cleaners, aerosol sprays, solvents, alcohol, ammonia, or abrasives to clean iPhone.
I've used Flents' "Wipe 'n Clear" eyeglass cleaner on the iPhone screen: It claims it's gentle on delicate or thin glass. It does contain rubbing alcohol however, so to err on the side of caution I use only water now.
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
I'm going to suggest that the warnings are there to:
a) Stop you spraying liquids onto or into your iPhone
b) Stop you using anything caustic or abrasive that may damage the finish
As these wipes avoid both of the above issues, and are a lint-free moist towel, they fit the bill and work superbly.
The problems with LCD and Plasma screens seem to occur when people use liquid cleaners, and that liquid wicks between the layers of glass leaving a watermark... :(
http://gizmodo.com/gadgets/cleaning/this-is-why-you-shouldnt-clean-your-hdtv-with-windex-251527.php
Not recommended! :(:(:(
robtob
Jul 17, 2007
I would assume it's likely that a scratch or blemish-protective coating was sprayed onto the iPhone screen during production. Couldn't nonpolar solvents like rubbing alcohol or ionizing solvents like ammonia remove such a coating?
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
The screen is supposedly made of optician's glass, so I don't think the ammonia would affect it. I could be wrong, tho.
uPhone559
Jul 18, 2007
389
i got a bottle of monster screen cleaner for $13 at Circuit City and have used it on my plasma's for over 3 years and the bottles only half empty, works great on sunglasses and iPhones too!
