GreenPoison A5 chip Jailbreak?
bballrob
Oct 11, 2009
1,930
479
Alaska
Well, I finally got it to work. After a full restore. WiFi was on, only because I forgot to turn it off. But after restoring my iPad2, the Absinthe JB ran first time without a hitch!
WOOOOHOOOOO!
  • Like
Reactions: Bennyboy
chazm
May 1, 2008
729
40
WTF they need to figure out a way to get the windows version to run. At least acknowledge that their is a problem.
At first I thought the servers must be busy. But not a 1 am the 3rd day it's been available
/rant
I know it's free and they don't have to do anything. Just annoyed because I need to tether my tablet for work
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
How do you do that? Is it hard
It took me a few tries; it doesn't like iPhones with a lot of data (music, apps) on them, so I finally did it successfuly with a newly-restored iPhone.
I had to restore last night because of something I did that went astray. I used the GUI jailbreak Absinthe 0.2 and it went fine with no hiccups.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Think I'm jumping in the next day or 2.
I'll let you know how my windows JB goes.
Naps, what do u consider too much data? I've got 7 GB of music and 3.5 GB for 2 films.
I've heard some people say it's best to start with a phone that is mostly empty, especially if you are using the CLI. You can backup, remove all content and settings, jailbreak and then restore your backup. I'm sure you'll be using the GUI since it's available now, so I'd try it first without removing anything. My jailbreak only took 7 minutes and I had 20 GB used space before starting. I used a Mac.
VOLS34
Jun 25, 2010
1,119
79
Did everything just like it said. Ran the tool, plugged my phone, it recognized it & I hit jailbreak. The status bar moved a little & said preparing jailbreak or something like that. The phone did nothing. Waited almost 2 hours to give it a chance & nothing moved or changed. I decided to unplug & try again now when I run the tool it says I attempted to jailbreak & it failed & then says restored successfuly. WTH
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Did you try to restore as new, jailbreak and then backup your phone?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Just to be sure. I need to connect to iTunes, restore to original setting, jailbreak, then restore from backup?
Look at post #69 by Europa in this thread.
Sorry I made a mistake, didn't mean to say restore as new.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
That really doesn't help me. Maybe there will be a fix soon.
I would personally restore my phone and try again. remove all songs if you have a lot on them your phone, you can always sync it back.
