Gruppled Theme Help
diverdown
Sep 12, 2007
971
49
NYC
I have followed the guide listed on this website:
http://www.hackthatphone.com/3x/themes_with_winterboard_section27.html
I used the creators custom Theme files located on page 3. The only thing I updated was the weather for my zip code. Everything installed ok, however, my mail, calendar, missed calls, VM and SMS all read 0 even if there are new items....Also I don't have arrows at the far right for those categories (I am assuming that is the case since they read 0).
Has anybody run into this and if so any advice?
~S
KabaModern
Mar 31, 2008
4,549
31
Philadelphia, Pennsylvania
~S
Ensure you have the latest version of Lockscreen Info from Cydia (1.0.107). Then, go into Settings > LockInfo > Calendar and change the "Max Events Shown" to "All" and then reboot your iPhone. You should be able to toggle back to whatever amount you'd like after you do this, but I think it's a bug with the newer version of Lockscreen Info with the Gruppled theme...
Krunk83
Jun 28, 2008
4,605
~S
Didn't you say that the calendar was the only thing working? I know there other day there was an update for lock info, make sure you have that like Kaba said.
diverdown
Sep 12, 2007
971
49
NYC
The top calendar next to the time pulls down and shows the month and the weather works.
The next items are mail, Calendar, Missed Calls, Voicemail and SMS....this is where new messages and appointments are supposed to tally....however all of them still read 0 even when new messages are received....
~S
KabaModern
Mar 31, 2008
4,549
31
~S
Can you report back if you tried what I suggested with the calendar setting? It should fix all problems of displaying "0" in all categories (SMS, Mail, Voicemail, etc.).
Krunk83
Jun 28, 2008
4,605
My seems to work fine without doing this but I did it anyway just in case. I'll set it back to the default setting once done rebooting.
diverdown
Sep 12, 2007
971
49
NYC
Fixed ! Awesome...thanks very much. That's why this community rocks.
Thanks to Krunk for the initial walk through and help with SSH and thanks to KabaModern for the end fix.
Very much appreciated,
~S
Krunk83
Jun 28, 2008
4,605
~S
Nice, enjoy. Did you see my post in the screenshot themes thread how I changed the tea_lockscreenbackground photos? It's pretty cool.
scottjf8
Aug 12, 2008
528
I can't SCP into my iPhone. I have SSH turned on, and I can ssh into it just fine.. but scp seems to be failing.
Is there a setting to enable scp?
