gym rats!
DHTPHTG34
Dec 30, 2007
Has anyone had problems using their iPhone in the gym working out and paticurlary in the sauna.
It gets to be about 180 or 190 for about 15 min.
I have done it about 5 or 6 times with no bad results like condesation?
I just do not want to keep chancing it if someone has had other problems.
thanks,
guest 5
Jul 5, 2007
614
NO!
I would not use my iPhone in the sauna!
Here is what Apple's support website said about the operational environment for the iPhone (See attachment).
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Yeah I would avoid a areas of both extreme heat and humidity (Florida, gah) and wouldn't risk it.
1,745
52
Long Island N.Y.
I used to wear my eyeglasses in the sauna, They are polycarbonate lenses with anti glare and scratch resistent coatings, unfortunately after 5 sessions in the sauna, my lenses coatings actually crinkled up, making them worthless.
Luckilyy i had them under warranty. The iPhone has a glass front so that will be ok under most any temperature, but the internal parts are probably much more sensitive, and batteries should not be exposed to high heat, not to mention when you heat up an object to 180 degrees and then cool it rapidly to room temp (when you leave the sauna) condensation forms, and thats never good for electronics.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
What the hell!? I hardly bring my phone to the gym unless I'm doing cardio, muchless into a sauna! If your phone craps out, that'll suck because I am sure you've set off the water damage indicator.
My advice would be to not bring jt into the sauna...
iMerlin
Sep 20, 2007
662
Algonquin, IL
I saw the title of this thread and decided to chime in even though its not in regards to the sauna.
I use my phone at the gym everyday. I found this website that allows you to track your workout progress. Its called Gyminee.com and it is pretty slick. You can preload your workouts or select workouts other users have posted. Then while you are working out just enter your progress and track it for next time. The site also has a new nutrition section that is soon to be up and running.
With that said, I would not use my phone in the sauna.
tyoung
Nov 1, 2007
185
So Cal
I won't even use my iPhone at the gym let alone the sauna. I don't think I'd take ANY electronic device in there.
guest 5
Jul 5, 2007
614
i don't use my iPhone in the gym, because when I run or do anything that involves me needing or wanting to change tracks without looking at the device is harder on the iPhone than with my nano.
Spikefood
Oct 3, 2007
368
Double clicking the mic is hard?
DHTPHTG34
Dec 30, 2007
Thanks for the reply's
I will not be using my iPhone in the sauna anymore.
However, i used my Motorola SLVR in the saun for 3 to 5 times a week for over 2 years. The only thing that went wrong was the Micro SD went bad.
I know the iPhone probably has a lot more sensitive internals than a SLVR, so no more sauna.
thanks,
justahsquirrel
Jun 7, 2007
545
Queens, NY
I would not take it in the sauna....too moist for my taste.....electronics don't mix..... i did take it to the gym to work out with...but i didn't have a blet clip or a holster....i had it in my pocket and certain exercises made it fall out of my pocket..just as anything else would.
impaler
Apr 28, 2007
522
thanks,
DOOD! Way bad idea, in the sauna.
coal0101
Jun 30, 2007
125
treo likes it
I used to take my treo in the sauna...but that was a work phone:)
I wouldn't take the iPhone. I don't even like to take it near the bathroom. I have read way to many horror stories of iPhones going for a swim in the crapper.
pjw
Sep 22, 2007
86
it is because i don't use the regular headphones because they hurt my ears. i use a sony behind the head headphones.
solder your sonys on the Apple wire. it takes like five minutes. there are videos around for it.
