halo 3 theme
duckcall
Sep 11, 2007
57
alright I got everything working with1.1.1 and want to make like a halo 3 theme. What do I go about doing?
jeff
duckcall
Sep 11, 2007
57
alright i have tried everything and cant figure it out, its suppose to be through summerboard but i cant get it to load.
its this theme if anyone can help
akophone
Aug 1, 2007
300
Not too familiar with PC or the current status of 1.1.1 3rd party support but I have the Installer on my iPhone and have added additional Community Sources like HighTymes.
To access this source, go to this thread and on the second post, you'll find HightTymes' post with a downloadable "Additional Installer Sources" and instructions on where to put this source file.
You'll then find these sources in Installer under "Themes (SummerBoard)".
These files, when installed, will show up on SummerBoard's pref Theme selection in your iPhone.
On the Mac, I just perform SSH to add some themes (that are not found on the Installer) where SummerBoard/Themes folder resides.
Good luck!
duckcall
Sep 11, 2007
57
it says i must install summerboard through installer, but they only have 2.11 they wont allow 1.1.1 . when i did just install the 2.11 it moved my dock to the top of the screen. then i uninstalled it crap is still on the top of the screen. i think i may have to restore and start over unless you have a fix?
scandalex
Sep 16, 2007
771
This post helped me a lot. Summerboard in Installer.app moves the dock to the top of the screen. Use Summerboard in iBrickr.
duckcall
Sep 11, 2007
57
i still cant figure this out i have done everything i can think of and i got nothing. all i have been able to change is the carrier logo. any help?
