Hardware changes
gamedude9742
Feb 27, 2008
78
USA
Looking around online i saw that there are replacement parts for the iPhone v1, and also the 3g. Now the antenna for example, it is thin to the point that there could be two inside the phone and it would cause no problems. Now if where the antenna connected to the phone's main board i slipped another antenna in there so that there would be two antennas, would it make my signal better? or worse in because it sucked away resources from the one to split it for two...
Any help is greatly appreciated!
Also is there any replacement lock buttons for the 3g out there, my lock button dosn't work well it seems smaller and less pushy than any other on any other 3g i have used.
guest03
Mar 30, 2009
80
adding two antennas will kill your battery life a lot quicker, trying to always search for a better signal. i would recommend it.
gamedude9742
Feb 27, 2008
78
USA
yeah good point, i didn't even think about the battery which is always dying on its own without my help ;)
I think i will just leave my phone alone, its service isn't horrible so I'll just leave it alone.
