Harman/Kardon Drive and Play works with iPhone
abohsali
Jul 12, 2007
45
Hello,
I have the Harman/Kardon Drive and Play iPod interface (with the wheel and LCD) installed in my car and tested it with the iPhone today. Wen connected the iPhone says that this accessories is not compatible with the iPhone message... but the it works very well though like it does with the ipod. You can navigate through playlists and all the functions including charging the iPhone. I am happy about that:)
222psm
Jul 14, 2007
Hello,
Cool I have a drive and play in the box, I'm gong to hook it up this weekend!:cool:
badtzki
Jul 18, 2007
Hello,
Thanks for the info! I also have one and was wondering the same thing.:cool:
bigmac
Jul 13, 2007
110
Los Angeles
any updated? have you guys installed this device? any problems? Does the phone work too?
pierce the veil
Aug 14, 2007
102
are you guys using the drive + play or the drive + play 2?
and yes, im also wondering if using the phone function while in it works.
i have a 5g itrip im using, but i have to be in airplane mode.
can you guys use it without airplane mode and it sound just fine?
iLLGT2
Jul 26, 2007
211
NY/LI
I must say, I'm also happy with this phone for that feature. I had an iPod dock, now my iPhone hooks up with no problem what so ever ! :)
bambam26
Sep 7, 2007
119
Atlanta, GA
I think will look into this device tomorrow? Thanks for the info.
Aug 10, 2007
11
i have this device in my element. i use it for my ipod throught the wired fm modulator. sounds okay with a little static in the background, but that is to be expected. the iPhone does work with this device but there is a lot of interference from the phone heard through the car stereo. When the phone rings, even more interference. if you put the phone into airplane mode there is no interference at all. that is the drive and play 1. i have no frame of reference for the newest drive and play.
pierce the veil
Aug 14, 2007
102
what firmware are you using?
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
I have 1.0.2 and have had the drive + play since June. iPhone works great and I think the above poster was a little negative. It plays over the fm transmitter better than a monster does. The "interference" is the same on ANY fm transmitter. Good buy.
Aug 10, 2007
11
with the wired fm transmitter on the the hk d+p1 i have a lot of interference. it may be a situation of the location of the phone to the head unit of my car. do to the length of cable that comes with the dp1 and the location of the control box of the dp1 in my car, my ipod and iPhone are no more than 18 inches away from the head unit, and i do get a lot of interference when the iPhone is not in airplane mode, but not any more interference than any other fm transmitter that close to the head unit with the iPhone.
i would also recommend getting the wired fm transmitter for the dp1 because of the poor strenth of the wireless fm transmitter. especially if you live in any moderatley populated area. also the last time i looked crutchfield.com was giving the wired module for free with the purchase of the dp1.
also i used it before with firmware 1.0.2, no difference after the upgrade.
pierce the veil
Aug 14, 2007
102
hmm then it must be my drive and play, for some reason it stopped working after i upgraded it.
wd8nvr
Mar 12, 2009
Does the iPod touch or iPhone also charge when connected to the HK driver and play? I have a Belkin device that works fine with my older iPod, and while it works with the iPod touch for audiop and playing, it will not charge the iPod touch.
cevtv
Nov 23, 2008
51
No, it does not charge. With the Scosche adapter it works great though.
