Has anyone else noticed a lack of responsiveness when scrolling down friends lists in Facebook?
TH55
Oct 30, 2011
356
9
In Facebook mobile when you scroll through friends lists now every third swipe to scroll down doesn't respond. Extremely annoying.
Rafagon
Dec 7, 2011
7,569
1,227
47
Miami, Florida
I have no lack of responsiveness whatsoever. I didn't count the swipes I needed to go down my entire list, but it was more than three. See my output below:
iPhone 5 / iOS 6.1 here, what configuration do you have?
I don't use Facebook anymore, but I didn't have that problem when I did. There are a lot of possible causes for this, but I'd start with a hard reset. If that doesn't work, try resetting all settings. Which phone and firmware version do you have and is it stock or jailbroken?
TH55
Oct 30, 2011
356
9
I'm talking about Facebook's mobile site, not the app.
Rafagon
Dec 7, 2011
7,569
1,227
47
Miami, Florida
I just tried going to m.facebook.com and when I tap on Friends, it doesn't list all of them. Instead, it lists a few friends under each of three categories: Online Friends, New Friends, and Recently Contacted. I don't see a way to make it list all of your friends. Because of this, the list isn't even long enough to give it time to gain any speed in scrolling, and hence, I get no lag or lack of responsiveness whatsoever.
If you have the specific URL you are using in order to get the mobile site to list ALL of your friends, share it and I'll be happy to test it for sluggishness. Leave out the "&user=##########" part if you don't want to expose your personal FB page.
I also would suggest to try the app instead of the mobile site and see if you get better performance out of it while scrolling through your friends list.
TH55
Oct 30, 2011
356
9
The mobile site does not have the "recently added, online, etc" categories when viewing someone else's friends list. It is simply a list that you have to keep scrolling down and loads 20 or so at a time. I am still running iOS 5.1 however so that might have something to do with it.
Why not update to 6.1.1? There's an untethered jailbreak available and a restore will likely fix this problem.
TH55
Oct 30, 2011
356
9
I would like to, but for some stupid reason several of the main tweaks I use are not available for the new 6.1.1 jailbreak. I read the list but can't find it now and so don't remember exactly which ones aren't but I know there were several of them, maybe you can tell me. Here are my mainstays:
Swipenav
Sleipnizer
DeleteWord
NoSpot
Call bar
Shake to undo killer
Zephyr
Double @@
Transparent status bar
Weather icon
Also, I've heard mixed-bad things about the new Google Maps and Apples new native map program.
Do these work in the 6.0 jailbreak?
Here's the 6.1 - 6.1.2 jailbreak compatibility for the apps you listed:
CallBar - yes
DeleteWord - yes
Double At - yes
NoSpot - yes
Swipenav - yes
Sleipnizer - yes
Shake to undo killer - yes
Zyphyr - yes
Transparent status bar - ?
Weather Icon - no
