Has anyone used Zephyr?
TH55
Oct 30, 2011
356
9
I posted this in my large thread but no one responded.
I am having trouble with it....I have it set to where swiping from the bottom can both close the app and trigger the multitasking bar.
However, in order to activate the multitasking bar I have to hold it there for a second. I have the delay set to the lowest possible setting, but it still takes a second and it severely hampers the smoothness of the tweak. Is there any way to make it so it is based on how long you hold your thumb on there while swiping?
In other words if you just flick it and let go right away it activated multitasker and if you hold it down longer as you swipe up it closes. This would make much more sense.
If not is there a way to do this with activator?
fijiman
Feb 13, 2011
832
64
UK
It's dependant on the speed of your finger moving up the screen....a fast long motion dismisses the app....an exaggerated slow short motion shows the switcher...;)
