Have I lost my Jailbreak?
IceCold357
May 1, 2009
571
39
I was on 4.2.1. and today I went to reboot by phone because an app was not installing. Well not I am in a continuios boot logo. It starts with the Apple and then goes to the skull. I am trying to pull it up on Tiny Umbrella but it is not recognizing the phone. Am I screwed?
IceCold357
May 1, 2009
571
39
Well I guess I am done. I am restoring and updating now. I have been running 4.2.1 Jailbroken so long I am out of the loop. Is there an Jailbreak (untethered) for 4.3.5?
Lon
Jun 5, 2010
2,946
132
Alaska
No, there isn't. But if you have your SHSH Blobs saved, downgrade to 4.3.3 and you can jailbreak by going to jailbreakme.com on the Safari browser on the iPhone, among other ways.
  • Like
Reactions: IceCold357
IceCold357
May 1, 2009
571
39
Wow. I am so frustrated right now. Okay I think I have my Blobs saved on Tiny Umbrella but I will have to wait for the phone to restore to check. Can you tell me where I can look to see how to downgrade to 4.3.3. Is jailbreakme.com untethered?
IceCold357
May 1, 2009
571
39
Nevermind. I found the steps on the redmondpie site. I will try to download 4.3.3 firmware and then rejailbreak.
IceCold357
May 1, 2009
571
39
Okay I am attempting to downgrade to 4.3.3 and I just keep getting the 1013 Error. I have tried using Tiny Umbrella to kick it out of recovery but it just keeps going right back to recovery mode. I am stumped.
IceCold357
May 1, 2009
571
39
I have tried the fix to the 1013 error by going into terminal and nothing is working. Still can't restore to 4.3.3 I am just about to give up. I can't have an un-jailbroken iPhone. Just can't.
Open it after you get the 1013 error. You use it instead of pressing "fix recovery" or "exit recovery" in TinyUmbrella.
IceCold357
May 1, 2009
571
39
I'm sorry Europa for all the questions I am just really frustrated. When I download the Fix Recovery for Mac, there are two programs I can click. Fixrecovery43 and Fixrecovery421. The only one that actually works is the 421 so I assume I am suppose to use that one.
Okay I got the Fix Recovery to work and had all the code on the screen. Now it is back to the iTunes with the USB Cable. What should my next step be?
IceCold357
May 1, 2009
571
39
Ohhh Okay so I need to downgrade just like I normally would and then when I get the 1013 I need to open fix recovery?
IceCold357
May 1, 2009
571
39
I got the "iPhone is not eligible for this build" so I think I need to go back to the text editor etc/ deal that I did earlier.
Correct. I would try it right now, though. If it doesn't work, restore and then open it after you get 1013.
IceCold357
May 1, 2009
571
39
Okay...I am calming down, lol. I have got it downgrading to 4.3.3 right now. It's gotten farther than it did before. So when I get the "1013" I need to click the fix recovery as soon as the "1013" pops up. What do I do after that? Do I need to click anything else?
Take a Xanax. :p
JK. It should boot after you run Fix Recovery.
