Having a Problem.
iCreep
Nov 14, 2007
84
For some reason when I uninstall apps from installer they aren't going away on the home screen.
Can anyone tell me why that is?
iCreep.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
have you reset the phone yet?
if so i think that you can get mobile finder and then go in and manually trash the apps....
iCreep
Nov 14, 2007
84
By reset do you mean turn it on then off or hold down the power and home button? Because I have shut it off and turned it back on...
And I'll give mobile finder a shot. Thanks for the advice.
iCreep.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
yes no prob.. i do have to credit that to macmanpro... he is the one that told me that there are somethings that stay on there sometimes...
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
oh yes and that is what i meant.. turning it off and on the way that you did...
iCreep
Nov 14, 2007
84
Well good news I got the icons off finally. Thanks a lot for the advice and mobilefinder worked perfectly. Thanks a lot.
iCreep.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
glad to see that it all worked out for you.... and that mobile finder thing was brought to my attention by macmanpro ...
