Having trouble with an app
harleygold
Jul 26, 2008
218
Anderson, IN
I have a app game called Solitaire City and when I tap to open the program it shows a pop up saying, "this application Solitiaire City cannot be opened". How can I go about fixing this?
thanks,
Carrie
Jul 16, 2008
1,592
Colorado
thanks,
Carrie
I haven't used that particular app so I'm not sure if it is buggy or maybe you just have a bad install. You could try deleting it then reinstalling.
harleygold
Jul 26, 2008
218
Anderson, IN
ok, i tried that. Somethings wrong with the application, because I tried to download the application from my library to no progress. It just said an error downloading. :(
thanks for your time,
carrie
dturner
Dec 15, 2007
5,725
Louisville, Ky.
carrie
What you need to do is delete the app from your phone and iTunes. I would then reboot both. Then go and download the app again from the app store. See if it works this time.
