Headphones
TexasRN
Dec 22, 2010
25
My iPhone 6+ has suddenly put itself on headphones instead of ringer....no headphones plugged in but I have plugged and unplugs set to see if would reset, didn't help. I have done a hard reboot, holding home and power buttons, and reset my settings each without success. Can anyone help me change this?
TexasRN
Dec 22, 2010
25
Also, when I reset my phone iMessage turned off, I've turned it back on but it's not working. Do I need to be on wifi for that to kick back in?
Dec 15, 2008
5,386
340
Pensacola, FL
As for this, sometimes it takes a little while for iMessages to kick back into gear when you turn it back on.
Per your headphone issue, have you tried taking headphones and plugging them in a few times and then unplugging?
TexasRN
Dec 22, 2010
25
iMessage has come back on but I still have the problem with the headphones instead of ringer. When I get a call I can't hear the caller because I'm not using headphones. This is really aggravating.
Dec 15, 2008
5,386
340
Pensacola, FL
Per your headphone issue, have you tried taking headphones and plugging them in a few times and then unplugging? There are several other tricks online to fix this.
5,578
It probably has lint in the headphone jack. This gives the phone the impression that headphones are plugged in. Shine a light into the port to see if there is any lint. You can remove it with a paper clip or compressed air.
iMessages can take over an hour to activate. Give it some time. It needs a network connection, but it doesn't matter if it's WiFi or cellular.
5,578
They said they tried it and it didn't work in the original post. It probably just jammed the lint in deeper. Compressed air or a paper clip can be used to remove it.
Dec 15, 2008
5,386
340
Pensacola, FL
My bad. I have reading issues, but yes compressed air I also read online, although I've never had this problem. :p
Paper clip?? I'm scared to use that just to get the sim card out. I had Apple send me the tool as I've never been sent it ever.
TexasRN
Dec 22, 2010
25
I'm going to try compressed air to see if that works. I'll let you all know as soon as o get the compressed air lol...thanks for all the help.
5,578
Cheaper way I read is to just blow into the jack.
It doesn't work as well. It's not going to be enough pressure if it's really jammed in there and you could get moisture in the jack.
Dec 15, 2008
5,386
340
Pensacola, FL
Do you have a case on your phone? I'm just curious to know how dust gets into the jack. Anything is possible. :p
TexasRN
Dec 22, 2010
25
Yes I do, but there are cut outs on the headphone jack, the charging port, and the speaker. Guess I need something a little more protective. It's from Spigen.
Dec 15, 2008
5,386
340
Pensacola, FL
I have a Spigen clear back case on my iPhone 6+. This is the first time I've not had an Otterbox Defender. I keep phone in pocket when moving about, and haven't had dust in jack issue, but not saying it's not possible. :)
TexasRN
Dec 22, 2010
25
Sounds like same case I have..mine is clear as well.
Dec 15, 2008
5,386
340
Pensacola, FL
I like not having a bulky case anymore, especially since I have a bigger iPhone now.
Anyways, back on topic, I'm glad all is fixed relating to the issues you were having.
TexasRN
Dec 22, 2010
25
Thank you for the help. And, this is the first time I've ever had and issue with dust in the jack, and I'm a VERY loyal iPhone user.
