Headset jack dust cover
Flyingstar
Jul 29, 2007
343
So. Cal
I'm looking for something I can use to keep dust out of the headset jack. Has anyone found a source for one?
kylegod
Jan 1, 2008
581
Bethlehem, Pa
no someone really needs to make a nice little rubber plug for it though
Flyingstar
Jul 29, 2007
343
So. Cal
Hey I found something that works pretty good! IN a hardware store (Do it center) I found a "auto body panel" fastener. Its black plastic with a sort of head or cap and a barbed part that fits in the headset hole. be careful not to push it too far down as it gets hard to remove. I sanded the barbed part down a little with some 220 grit wet & dry so it comes out easy. cost: 39c (they come in a bunch of sizes, this being the smallest)
Proudfoot
Dec 3, 2007
I use the rubber grommet that comes with the old nokia 6310 cut down to size - had a few lying about -. Works a treat.
:cool::cool::cool::cool::cool:
