Help! Blank Safari Icon
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Try a hard reset. Hold the home and power button at the same time. Ignore the slide to power off. Keep holding until you see the Apple logo. Wait 60 seconds ish and phone will be back to normal so should safari icon.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Are you jailbroken? If so that's been happening to bunch of people. Just do a reset or just respring your phone. Eventually it would go back to normal. It happen to me last night.
enjoylife1788
Jan 7, 2011
186
Mostly u are jailbroken. Such instances on non jailbroken are very rare.
U can go to sbsettings-system options- fix user dir permissions.
That will take care of all your white
Icons..
Adriano73
Jan 17, 2012
337
77
UK
Yeah, I undid theme, then after 3 or 4 resprings it went back to normal. It was the camera app for me.
Sent from my White 64gb iPhone 4s in a white Lifeproof Case using iCafe app
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Also, open SBSettings>Dock application>Fix blanks. Thats the fastest way without installing anything else.
Adriano73
Jan 17, 2012
337
77
UK
that's the one! Thanks man, it's good to know that's there.
