Help: bought an iPhone from eBay
skiz420
Jul 28, 2007
371
Boston
its fine... it was just that the previous owner had put music or pics on the phone and iTunes wants you to clear it all out so you can put your own stuff on there.... it reads what computer it is connected to ... its best to clear it all out anyway.... welcome to the EI fam... enjoy the iPhone and hang out and share on the boards..
ellicit
Sep 14, 2007
but will this effect application like installer, and will the phone become locked again?
I have summerborad, PDF viewer, backjack I love these apps, and I don't wan them removed! and I don't want it to lock again!
let me know please
skiz420
Jul 28, 2007
371
Boston
no this only affects the iTunes library it has nothing to do with the firmware.... it should only erase the music, pics, and videos that are on the iPhone... the only time it would affect the unlock is if it was a restore or and update that restored your phone but this is only connected to the media on the phone not the firmware itself
bnelse92
Jul 29, 2007
Do you mean pics you have taken with the iPhone? If so, then they will not go anywhere when syncing with iTunes, they will still be on your phone. One thing I would do before syncing is to set iTunes to sync manually and not automatically. That way, you can control exactly what syncs and when. If you have any custom ringtones on your phone, make sure to uncheck the "sync ringtones' tab in iTunes. Also, if you are on firmware 1.0.2 then do not update the iPhone if you are promted to by iTunes, it will wipe all of your apps. There are lots of ways to re-add them, now that the new firmware has been hacked, but it may not be something you want to have to bother with.
